Perform this procedure to configure network policies on specific ports.
Configuring guest voice network policy on port 1/2:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#lldp med-network-policies guest-voice dscp 1 priority 5 tagging tagged vlan-id 5
The following table defines parameters for the lldp med-network-policies command.
| Variable | Value |
| {guest-voice | guest-voice-signaling | softphone-voice | streaming-video | video-conferencing | video-signaling | voice | voice-signaling} | Specifies the type of network policy. |
| dscp <0-63> | Specifies the Layer 3 DiffServ Code Point (DSCP) value, as defined in IETF RFC 2474 and RFC 2475. The default is 0. |
| priority <0-7> | Specifies the priority level, as defined in IEEE 802.1D. The default is 0. |
| tagging {tagged | untagged} | Specifies the type of VLAN tagging to apply on the selected ports. The default is untagged. |
| vlan-id <0-4059> | Specifies the VLAN ID for the port, as defined in IEEE 802.1Q. If you configure priority tagged frames, the system recognizes only the 802.1D priority level and uses a value of 0 for the VLAN ID of the ingress port. The default is 0. |
